\system\system32\ntdll.dll errror
20 years 3 weeks ago #7886
by spartacus
\system\system32\ntdll.dll errror was created by spartacus
guys,
i have this problem on my pc. when i install any os win2k,xp or 2003, after rebooting for it to continue to setup, blue screen follows saying this error c0000221 \system\system32\ntdll.dll . any idea what can i do ? ive already reformat and everything its just the same..
wheeewwwwwww...............
20 years 3 weeks ago #7891
by nske
Replied by nske on topic Re: \system\system32\ntdll.dll errror
I can think of four possible causes,
Either it is a memory issue (make sure you have not picked a wrong bus speed or latency interval from the bios, that the memory modules work ok with each other -try removing each one of them seperately-, and that they are no corrupt)
Or it is a temperature problem (check the temperature on the CPU and the graphic's adapter processor, as well as on the motherboard chipset -just touch them by hand after a couple of minutes of work if there are no sensors-)
Or there is a serious corruption at the hard disk,
Or it is an indefineable problem with some of your peripherals that causes this fatal error to windows (try removing each component -especially the pci devices- and testing without them).
- Biggystumps
- Junior Member
19 years 10 months ago #8648
by Biggystumps
MCSE - MCSA
2003 certified
Replied by Biggystumps on topic Re: \system\system32\ntdll.dll errror
Hello,
if the data is critical to get off the system, and provided that its not a serious hardware problem
i would try doing a parallel install of windows to get your data off of the server.
very easy to do. www.windowsreinstall.com
has screenshots that show you how to do them.
MCSE - MCSA
2003 certified
