WIRELESS NETWORK PROBLEM HELP NEEDED
19 years 5 months ago #11295 by lan2wan
Hi All,
Dalight, you were so right! Installing from the client end was so easy.
Router=DHCP
Win2k3=DNS
Bishop,
I will check the Firewall. But even after installation I cannot access the web management console from my laptop but I can access it from all the desktops.
Thank you all . I'll keep you posted.
PS
I have not forgotten about the picks, I've just been bogged down with a lot of work.
19 years 5 months ago #11298 by DaLight
Glad to hear that you've been able to install the Officescan clients. You will still need to check the XP firewalls as the Bishop suggested because the server will not be able to notify the clients when updates are due. Also, I would suggest moving your DHCP to the W2K3 server as well.
Re: Accessing the management console from your laptop
The management console requires Java to be installed, so make sure your laptop has Java installed.
