Bridging wireless internet and wired network.
19 years 7 months ago #9681
by o2oigo
Bridging wireless internet and wired network. was created by o2oigo
I've got one of my computers connected to my wireless router in the other room with a wireless pci card and everything works great. Only thing is, now I've got two more computers connected to this computer with a switch now. One uses SuSE 9.3 and the other Win200/WinXP. The one I'm on uses SuSE 9.3 as well. I'm sure its probably something simple, but how do I bridge the wireless connection with the wired? Its probably some option in YAST I missed or something. Thanks for the help.
19 years 7 months ago #9714
by Lindows
Replied by Lindows on topic A crack at it
i know when you want to bridge two internet connections. You usually have to hight light both adapter connections then right-click and select bridge connections. That usually how i bridge my wireless usb apater to my ethernet adapter and from my ethernet card to a switch that provides my laptop with my internet access.
Sorry if this doen't help
Lindows
Lindows
