Problem with memory
20 years 1 month ago #7446
by aminos
Problem with memory was created by aminos
HI
I have a box running RH 9.0 running as a local web server, the problem is when i first run it and type :
# free -m it shows that 44MBB are used
after a while without doing something
free -m shows this time 215MB
what's the problem if this sudden rise of memory usage ?
i check my services all seems normal , there's no scheculed tasks no Cron runnig and no one is connected to the server. i isolated from my lan but the problem remain !! is it a problem ?
my config is:
P4 2.5GHZ
256 MB RAM
40 GB hd
RH 9.0
Apache 2.0.52
thanks for all
my config is:
P4 2.5GHZ
256 MB RAM
40 GB hd
RH 9.0
Apache 2.0.52
thanks for all
20 years 1 month ago #7448
by nske
Replied by nske on topic Re: Problem with memory
Don't worry, this is typical behaviour of linux. It just uses free memory for caching and other things, but memory will be released if it is needed
