Problem with Knoppix :-(
20 years 1 month ago #7385
by aminos
Problem with Knoppix :-( was created by aminos
Hi
I have a Knoppix lice CD but when i boot it , all i get is :
enabling DMA accelaration for hda ----> name of my HD
enabling DMA accelaration for hdb
> my CD-rom
Looking for cd-rom in hda
can't find Knoppix filesystem sorry
dropping you to very limited shell
press reset button to quit
knoppix #
what's going on ?? i don't know ???????
is it a hardware problem ?
please help
> my CD-rom
knoppix #
please help
- cybersorcerer
- Senior Member
20 years 1 month ago #7388
by cybersorcerer
Gandalf the Grey
Replied by cybersorcerer on topic Re: Problem with Knoppix :-(
Try tinkering with boot options that you can pass into the kernel. I had conflicts with my DMA enabled drive and to fix it I passed the "ide=nodma" option into the boot sequence and I was able to boot knoppix correctly.
Gandalf the Grey
20 years 1 month ago #7394
by aminos
Replied by aminos on topic the solution
Hi
Thanks for your reply, but i found the solution :
at boot #knoppix noscsi nodma
or
# falisafe
but i have another problem, i think it's due to my network card
when it reashed the message :
Network device etho detected, DHCP broadcasting for IP
after that nothing happened
i want to know how to skip my Network card detection ?
thanks for all
or
# falisafe
thanks for all
19 years 8 months ago #9255
by sahirh
Replied by sahirh on topic Re: Problem with Knoppix :-(
try just pressing CTRL C at the DHCP line... it should escape that.. either way it doesn't matter too much, if you don't have DHCP, the DHCP will fail and you will be able to manually configure your network card.
19 years 8 months ago #9282
by ping
Replied by ping on topic Re: Problem with Knoppix :-(
I also have some probleme wiht my knoppix live CD. Well it boots ok but when the desktop is loading it displays following message :
[code:1]Not enough memory to start KDE! (At least 82 mb required)using TWM window manager instead ,
Caution : Not all programs in the left mouse-menu will work here!
It also displays the shell window which has this prompt
[code:1]knoppix@ttype0[knoppix]$[/code:1]
Now i have one Pentium IV 1.7 Gz. wiht 128Mb ram. In the menuals of the Cd i read that to start it in GUI mode i requiere atleast 82 Mb RAM. I have already 128 Mb.
What could be the possibel Issue?
- cybersorcerer
- Senior Member
19 years 8 months ago #9283
by cybersorcerer
Gandalf the Grey
Remember that knoppix uses a RAM disk to store the operating system in to mimic a live environment. When you subtract that from your available memory it is probably < 82 MB which is probably why it is blasting that error at you.
Gandalf the Grey
