i need help about webmin
20 years 6 months ago #5191 by Noori
hi ppl,
i have installed the webmin to linux 3.0 but then when i want to access to linux from other computer so it makes problem and not working. therfore i want to some body help me about this.
thank you
regards
noori
Sikandar Noori
20 years 6 months ago #5195 by FallenZer0
hi ppl,
thank you
regards
noori
--Please do NOT take this personally. I'm trying to help.
What do you mean 'access to linux from other computer so it makes problem'? If ONLY you could be more Specific about the problem(s), like say error messages or anything that would help others here to may be give you some directions.
And what is it that you want working?
PS: Chris, is it possible to make a post on how to ask questions, and make it sticky on each of the forums hoping people would read it, before asking questions. Just a suggestion.
20 years 6 months ago #5205 by Chris
Replied by Chris on topic Re: i need help about webmin
Noori,
As Fallenzero so correctly suggested, you need to be more specific on the problem and what your trying to do.
I have a feeling that your trying to setup Samba on that Linux machine and access it from a Windows box, but you need to clarify this and help us help you.
Fallenzero, your suggestion has already been implemented by Sahir for our 'Basic Concepts' forums. There is a 'sticky' thread which explains to people how to correctly format and present their problems. We might take that an extend it to every other forum since you've mentioned it.
