I need your help (linux man)
17 years 7 months ago #23165 by msalkhaldi
install ubuntu but I face some issue with it
1- I cant access by root username
2- I don't Know what is the root password
17 years 7 months ago #23169 by DaLight
That's because the root account is disabled by default (by having no password)
Login using the username you selected at setup and type in
[code:1]sudo passwd root[/code:1]
Then type in your new root password.
17 years 7 months ago #23178 by msalkhaldi
Replied by msalkhaldi on topic thanks
thank you very mach :D
17 years 7 months ago #23186 by skepticals
Do you need the root account in Ubuntu? Because I use the sudo command and simply use the password I used when I setup my normal user account.
16 years 4 months ago #28480 by talk2sp
Replied by talk2sp on topic hey skep u do...
skep u need root in ubuntu cos there are some certain features u will need access and u have to have an administrative right above the one u are using presently... that happens only in root.
BORN TO BE GREAT
c0de - 3
