Resized partition problem.
- skepticals
- Elite Member
17 years 2 months ago #23102
by skepticals
Resized partition problem. was created by skepticals
Well, I wasn't thinking when I did this. I had a triple booted computer with XP, Vista, and Ubuntu. I wanted more space so I booted off of the Ubuntu CD and deleted the XP partition and resized the Vista partition to include the new space. Ubuntu said everything went fine, but Vista won't boot now.
Is this because the MBR (or something) was on the XP partition?
_____
Note: I tried to do this: support.microsoft.com/kb/927392
But, I can't boot off of the Vista Disc either. It goes to a black screen after the spash loading screen.
_____
17 years 2 months ago #23106
Replied by TheBishop on topic Re: Resized partition problem.
Might be something like that. When you installed the three OSs, what order did you install them in? This will probably give you a big clue
- skepticals
- Elite Member
17 years 2 months ago #23113
by skepticals
Replied by skepticals on topic Re: Resized partition problem.
I installed XP, then Vista, then Ubuntu.
I researched a great deal yesterday and found others with similar problems. Some peopl think Gpartition works perfectly with NTFS partitions and others not so much.
I ended up giving in and backed up my data and did a format and reinstall. I couldn't even boot off the Vista DVD until I formated the drive. Must have been something with the boot loader, MBR, or partition I would think.
17 years 2 months ago #23116
If you installed XP first then as you say the MBR would be in that partition, and unfortunately you removed it. Never mind, at least you sorted it out
- skepticals
- Elite Member
17 years 2 months ago #23121
by skepticals
Yeah, I assumed that the MBR was on the XP partition, but I didn't know if Ubuntu worked some magic and the normal MBR wasn't needed or moved.
Either way, the format fixed it
17 years 2 months ago #23151
It would be nice to think so but it's not that intelligent. If it's any consolation I've fallen foul of similar issues more than once in the past too. Put it down to experience...
