Best method for dual booting
17 years 7 months ago #23078 by skepticals
Thanks for everyone's input. I ended up triple booting with Windows XP, Windows Vista, and Ubuntu Ultimate. Currently, everything seems to be working besides the wifi card in Linux. I need to get the correct drivers. Other than that, everything was really easy.
Thanks.
17 years 7 months ago #23085 by hash29
If you don't have linux drivers, just download ndiswrapper program and install. Then copy *.inf and *.sys files from your CD drivers for windows to linux directory and put command ndiswrapper -i xxx.inf, next write modprobe ndiswrapper. Finally you can see your wifi card by iwconfig, this will be wlan0. Then just configure internet connection by any wizard.
Best regards
Piotr Madera
registered Linux user #357427
17 years 7 months ago #23096 by skepticals
Thank you for the information. I had run accross ndiswrapper on a web site, but had not taken the time to use it. I will try it and see what happens.
17 years 7 months ago #23120 by skepticals
FYI: I ended up finding a blog with a person that made drivers for my internal wifi card. The process didin't go as the blogger said, but it ended up working. I will have to find it again now that I have had to format.
