Ubuntu problem
17 years 7 months ago #22755
by ping
Ubuntu problem was created by ping
Hello friends,
Recently i odered some ubuntu desktop CD's for my PC. When they arrived and tried to boot from that CD it showed me menu to start/install ubuntu and several other options since it was live CD from which you could also install.
But when i select the first option that is start/install ubuntu it just unpacks the kernal then whole screen goes blank..
What could be the problem??
I checked system requirements they were 256 Ram and 4GB of HDD for installation.
My PC's configuration is as follows:
512MB RAM,
40GB HDD
64MB Graphics Card
Intel 82845GLAD motherbord
Cheers..
~Pranav
512MB RAM,
40GB HDD
64MB Graphics Card
Cheers..
~Pranav
17 years 7 months ago #22787
by skylimit
Replied by skylimit on topic Re: Ubuntu problem
If you are absolutely sure you pc meets the minimum specification I'd suggest you download ubuntu off the Internet since its free. Also a good way to test software packages is to install them on a virtual machine like vmware an see what happens. Like this you dont mess up your system.
Are you installing the current version?
my 2 cents!
my 2 cents!
17 years 7 months ago #22790
by durk21
Replied by durk21 on topic Re: Ubuntu problem
ITs a graphics conflict when you are installing change the screen resolution to a smaller size especially if you are running 32 bit or higher. change it to a 16 bit format. ubuntu has trouble running larger graphical bit sizes such as 32 and does not support 64 as of yet I believe. That should fix it if that does not work I do not know what the problem is.
but to change the graphics to 16 bit I think you hit f4 or f6 at the install screen.
17 years 7 months ago #22803
by DaLight
Replied by DaLight on topic Re: Ubuntu problem
I can confirm that. I have come across this whilst installing Ubuntu previously.ITs a graphics conflict when you are installing change the screen resolution to a smaller size especially if you are running 32 bit or higher. change it to a 16 bit format. ubuntu has trouble running larger graphical bit sizes such as 32 and does not support 64 as of yet I believe. That should fix it if that does not work I do not know what the problem is.
17 years 7 months ago #22833
by durk21
was it fixed?
17 years 5 months ago #23430
by ping
Replied by ping on topic Re: Ubuntu problem
Yeah it was fixed...
But i still don't know the real problem.
I had put the LiveCD in CD drive and boot the pc and then went to do some other work around my place and after around 15 mins when i came back the desktop was loaded and was ready for use..
So i still don't know what the real problem is..
BTW ubuntu does suppor 64 bit.
Thanks for your help ppl
Cheers..
Ping:lol:
Cheers..
Ping:lol:
