Help, I need somebody, help not just anybody helpppp
18 years 7 months ago #16474
by Lindows
Help, I need somebody, help not just anybody helpppp was created by Lindows
Hi guys,
I want to install software on my laptop, but get the following errors.
checking for gcc..... no
checking for cc......... no
configure error: no acceptable cc found in $PATH
Lindows
I got this after trying to install programs like Tor, Vmware 5 and AVI on my Suse 10.0 Laptop
Lindows
Lindows
Lindows
18 years 7 months ago #16495
by Ranger24
Replied by Ranger24 on topic Re: Help, I need somebody, help not just anybody helpppp
Hi Lindows,
See www.novell.com/coolsolutions/feature/16340.html
Gives a step by step guide to getting SUSE ready for Compiling and how to compile.
If you need further help ask away and I am sure you'll get answers...
R
R
18 years 7 months ago #16523
by Lindows
Hey,
Ranger thanks for the help, I went to the link but i had a program. Well after running the command to check if i had gcc installed.
i recieved the following output:
rpm -qa make gcc
make-3.80-188
So, then i went to yast, and went to software management, but after install everything that related to gcc, my system still doesn't report it installed.
Any solutions,
Lindows
rpm -qa make gcc
make-3.80-188
Any solutions,
Lindows
18 years 7 months ago #16525
by Ranger24
Hi Lindows,
Please post the output of :
[code:1]rpm -qa kernel*[/code:1]
and
[code:1]rpm -qa make gcc[/code:1]
Then we can take it from there. I'm not overly familiar with SuSe but I am sure we can sort it.... and maybe others can offer advice.
R
and
R
