Help Installing Wireless Card
18 years 11 months ago #14610
by Lindows
Help Installing Wireless Card was created by Lindows
Hey Guys,
I need heelp setting up my wireless card. I have a intel Pro wirless b/g card built into my Dell XPS m140 laptop. I found a website that has the linux drivers designed to configure the card. The webiste is ipw2200.sourceforge.net/ .
Im running Suse 10.0 so far i extracted the files to each folder, but the install i can't get to run.
HELP!!!
HELP!!!
18 years 11 months ago #14611
by nske
Replied by nske on topic Re: Help Installing Wireless Card
Did you follow the instructions in the provided
INSTALL
file? If so, in what step does the problem show? Also please include the text of any produced message.
If there is some part of the installation procedure described that you do not understand, I'll gladly explain it to you in detail
