100Mb pc-to-pc using iperf question
14 years 1 week ago #36610
by pedenski
100Mb pc-to-pc using iperf question was created by pedenski
Hi good people of firewall forums,
Im quite baffled with the result im getting whenever i transfer 100mbps (pc1) going to PC2 using jperf.
Im sending 100Mbps, but All i get on the other end is only 7Mbps.
Setup:
PC1 manually configured (full duplex / 100Mbps) connected to 100Mbps switch port #1
PC2 Mannually configured (full duplex /10Mbps) connected to 100Mbps swith port #2
PC 1 is the client, and the one sending 100Mbps
PC 2 is the server and keeps getting only 7Mbps.
Setup:
14 years 1 week ago #36611
by Arani
Hi
Just noticed you configured the second PC as full duplex /10Mbps. Maybe that's the reason why it's getting only 7 Mbps. Why don't you try to set it up as 100 Mbps as well. Or maybe just put it on auto negotiation?
14 years 1 week ago #36612
Replied by S0lo on topic Re: 100Mb pc-to-pc using iperf question
I'd second Arani on that. It's probably because of that 10Mps. The speed of any connection is defines by it's lowest link. Make sure also that you used either Cat5e or Cat6 cables.
14 years 5 days ago #36624
by pedenski
Replied by pedenski on topic Re: 100Mb pc-to-pc using iperf question
Thanks for the reply guys,
It turned out i have a crappy laptop. I isolated the laptop and it seems im having problems with the previous. altho, i did check if the laptop is using 10Mbps but it wasn't.
