- Thank you received: 10
Serial Interface
14 years 11 months ago #34423
by Arani
Serial Interface was created by Arani
Hi All,
My desktop does not have a serial interface. Neither does my laptop. would a USB to serial interface work with a CISCO router/switch? If yes then is there a particular brand that does. I have heard that some of them don't give you full functionality of a normal serial interface.
Or is it just better sense to go buy a pc serial interface card instead.
14 years 11 months ago #34426
by Nevins
Useful Threads
Replied by Nevins on topic Re: Serial Interface
For the record you can use a usb port instead of a com port you just need an adapter. The only problem with usb that you may run into is that it may have an issue going into rommon. (you can fix that buy changing hyper terminal settings and simulating a ctrl break signal)
Useful Threads
