Expanding Wireless range with two routers
16 years 1 month ago #29127
Replied by S0lo on topic Re: Expanding Wireless range with two routers
I assume here that your desktop connects wirelessly to the router downstairs. Or is it wired?
Your problem (as far as I understand it) is in range. Since you can't connect the routers via a UTP cable, then you have to find a way to relocate the routers/laptop/desktop to make wireless range downstairs reach upstairs. Even if you find a way to pair the two routers, how are they going to reach each other if they are out of range?!! The problem is in physical location, as far as I understand it. Correct me if I'm wrong.
First, I'd try digging in the router (upstairs) UI config, see if there is an option were you can make it work as a repeater (range expander). I don't think there is but I'd check just in case.
Second, have you thought of relocating the router upstairs? can you put it in the middle (say near the stairs) so that it's easier for you to wire them together?
16 years 1 month ago #29129
by Onumis
Replied by Onumis on topic Re: Expanding Wireless range with two routers
thank you for your responses.
My desktop, downstairs, connects through wire, and yes, the problem is range, i've bean messing up with my routers config but until now no luck;
I can relocate the second router, upstairs, but 1st I have to configurate it properly.
I'll rest on the case, maybe i'll came up with an idea.
16 years 1 month ago #29172
by talk2sp
BORN TO BE GREAT
c0de - 3
are we sure its not a channel thing, antenna beacon, well Onumis ur problem is a little one cos i have experienced same and i tell u i made a post here and someone said something about having same wireless equipments on same channel and also changing the mode of one. R1 will be the main gateway, R2 will turn from a wireless router to a wireless AP. meaning that to connect to R@ u wil be using auth from R1
BORN TO BE GREAT
c0de - 3
