Fiber Networking, gear questions
16 years 9 months ago #26934 by toddwoo
Hi all...
Some of you know i've gotten a new job that involves configuring wan and fiber Ethernet services for our customers. The one major provider we work with installs the same devices at every location... so we tend to use them at every location.
www.telco.com/int/index/en/prodbyname/prod/81
Myself, and most all the other engineers do NOT like these. We have regular problems with them, and they don't seem to be getting any better with firmware updates. I'll save the on-call horror stories for another post...
Where we can we just leave them off, and jack the fiber directly into the gear.. but we can't do this everywhere.
Can anyone suggest any other equipment that we might be able to use in place of these?
16 years 9 months ago #26936 by TheBishop
It looks like it's basically a "we don't trust what's plugged on either end so we want our own monitoring box" box that happens to do a bit of QOS and bandwith shaping as well. If your business doesn't actually depend on these features I'd be tempted to leave them off too
16 years 9 months ago #26945 by toddwoo
Really we just need the transceiver, most people want an copper hand off not fiber, so these get put in.
We really don't care about almost any of the features, and i'm sure whatever we find to replace this will have some of them...
16 years 9 months ago #26948 by TheBishop
Then it looks like what we here call a SPOF (single point of failure). Why have a separate box in-line with your incoming feed when the router/switch can do the media conversion itself? It's just another power supply, mains connection, circuit board, bit of microcode etc to potentially go wrong
16 years 9 months ago #26950 by Elohim
Sounds like you just need a plain old media converter... look at transition networks.
Hi all...
16 years 9 months ago #26954 by toddwoo
First and foremost its the demarc. Thats where the ISP turns it over to "us" (the customers). If there is ever a problem you stick a laptop on the end.. and volia insta test...
Second, you would be shocked how many people will not accept a fiber hand off, if there is even a HINT at there being a copper solution available.
