Need a simple Definition for Tracert
16 years 8 months ago #26880
by Rickie
Need a simple Definition for Tracert was created by Rickie
when we do a tracert wat is the three lines denotes next to the S.No... is it a min ,max and average... if tats so.. wat does it means exactly.. ?
16 years 8 months ago #26884
Replied by TheBishop on topic Re: Need a simple Definition for Tracert
Tracert works by sending a series of packets to determine the routing hops between where you are and the destination address you specify. It does this by sending a series of ICMP echo requests to the far end. The first attempt has the TTL in the packet set to 1. The first router on the path decrements this to 0 and therefore cannot forward the packet, so it (the router) sends back a TTL exceeded message. Thus the router's IP address is discovered. Tracert then repeats the exercise but with a TTL of 2. The first router passes this, decrementing the TTL to 1, but the second router cannot forward the packet so sends back a TTL exceeded, revealing its address. And so on until either the destination is reached or you exceed the maximum number of hops that tracert is configured to allow.
Each line of output corresponds to one iteration of the TTL as explained above. The reason you see three times on each line is that each 'step' is tried three times, giving you three round-trip time figures for each hop along the route
16 years 8 months ago #26885
by Chojin
Replied by Chojin on topic Re: Need a simple Definition for Tracert
Nice one Bishop!
+1 Credit from Chojin
16 years 8 months ago #26895
Never knew that part before. Good question and great answer indeed.
Replied by S0lo on topic Re: Need a simple Definition for Tracert
16 years 8 months ago #26911
by Rickie
Replied by Rickie on topic Re: Need a simple Definition for Tracert
Thanks a lot GUys..... now i know how the tracert works and methodology... so its not min and max anymore... ... its just trying to send three times..Rite.. so
Time to create page: 0.242 seconds
