ISPs and Bit Torrent Traffic
17 years 2 months ago #24839
Replied by TheBishop on topic Re: ISPs and Bit Torrent Traffic
Like I said I don't think they will attempt to digest all their traffic, they will filter for just the IP address of the person in question and analyse that. From there they can filter even more tightly to capture just the torrent stream if they want.
There a re a few products that can replay a captured buffer onto the wire. We have Observer which can do that, plus as solo mentioned it can reconstitute both http transactions and voip calls, redisplaying the pages viewed or replaying the actual audio of the conversation as appropriate. I'm sure it is possible for torrents too
- skepticals
- Elite Member
17 years 2 months ago #24841
by skepticals
Replied by skepticals on topic Re: ISPs and Bit Torrent Traffic
How would the RIAA find out in the first place? Do they just get a list of IPs that are on torrent sites and have the ISP inspect the traffic more?
17 years 2 months ago #24846
by DaLight
Replied by DaLight on topic Re: ISPs and Bit Torrent Traffic
They have a number of tactics such as setting up "honeypot" sites and the suggestion you made i.e. getting IPs lists from "guilty" sites.
- skepticals
- Elite Member
17 years 2 months ago #24850
by skepticals
So it seems that it is easier to figure out what the traffic contains than I thought; however, it is just luck of the draw if you are a choosen one.
16 years 7 months ago #27083
by silentko
Replied by silentko on topic Re: ISPs and Bit Torrent Traffic
if if were you ill tell your friend to start using peer guardian 2. you can find it here
phoenixlabs.org/pg2/
. Also some torrent clients like Utorrent and bittorrent have encryption build in them.
Hope this helps.
Hope this helps.
16 years 7 months ago #27118
by ZiPPy
ZiPPy
Replied by ZiPPy on topic Re: ISPs and Bit Torrent Traffic
This Peer Guardian 2 looks rather interesting. Is anybody else running it? What are your thoughts?
A buddy of mine (actually a user here on f.cx) attended DefCon last weekend. And we were introduced to Tor. Is peer guardian and Tor along the same lines of keeping packets private?
ZiPPy
ZiPPy
ZiPPy
