ISDN Question (Spawned from Article)
17 years 11 months ago #22128
by akant
ISDN Question (Spawned from Article) was created by akant
I read the article on the basics of ISDN however there is one thing that has me confused. Everyday I work with clients who are having all data T1's install for general Internet access. They are usually terminated on routers that we support however I am curious if you would consider these types of products we are receiving has PRI T1's . They terminate into regular Cisco Internal CSU/DSU WICS.. are these technically PRI's ?
Looking that the interface configuration there is nothing specific for ISDN, just HDLC ..etc to the provider
Are there two types of "T1" products ? I have heard of "CAS" and ISDN "PRI" difference?
Can someone shed some light here for me?
and help me visualize the differences.
Thanks!
Kenny
Thanks!
Kenny
17 years 11 months ago #22210
by anti-hack
Replied by anti-hack on topic Re: ISDN Question (Spawned from Article)
Well T1/E1 is basically a type of a link. E1 is the European/Asian kind and the T1 is the North American and the Japanese type. The E1 has a bandwidth of 2 Mbps and the T1 has around 1.5 Mbps. PRIs can be both E1 or T1 depending where you are located. If you have a T1 line then the number of channels are 23 and if you have a E1 line then you get 30 channels.
Hope that clears something,
17 years 11 months ago #22232
by Ranger24
Replied by Ranger24 on topic Re: ISDN Question (Spawned from Article)
CAS and ISDN refer to the signalling protocols used to carry call state & feature information.
CAS = Channel Asociated Signalling
ISDN = Intgrated Service Digital Network
CAS is very basic and can be thought of as the first digital signalling protocol to be used in Telecommunicatons
Hope this helps.
R
Hope this helps.
R
17 years 11 months ago #22241
by Smurf
Replied by Smurf on topic Re: ISDN Question (Spawned from Article)
thats what i thought but wasn't 100% sure. The thing that confused me with this post was
As the Article states, it can use PPP or HDLC as its encapsulation protocal so the fact its using hdlc isn't that odd as this is just the point-to-point encapsulation thats being used.
It does have me curious if no ISDN commands are in use though.
Seemed a little odd. Do you know if CAS still uses the ISDN commands to configure the serial link ?Looking that the interface configuration there is nothing specific for ISDN,
17 years 11 months ago #22260
by Ranger24
CAS predates ISDN by approx 5-10yrs. So CAS doesn't use ISDN commands at all.
CAS signalling is related to basic call setup & clear down commands and really doesn't have any in built capability for call features (i.e. channel bonding).
I guess in a data network as you are using the CAS circuit for bandwidth then this is all that is needed.
br
R
br
R
17 years 11 months ago #22261
by Smurf
Cheers fella, that makes more sense
