creating Roaming Voip connectivity through VPN: Urgent Help
19 years 4 months ago #11684
by Gobinatty
Hi All.
I was asked to setup a demo VPN connectivity from my Win XP home edition laptop in which i have downloade nortel ip softphone to my office setup which has got contivity 100 Instant Internet -s via ADSL modem. i want to test my Ip softphone working through this setup. is it possible from the above setup if so what i need to do. else what is your valuable suggestion. please reply me ASAP to get things moved.
Looking for your valuable reply at earliest.
regards,
gobinatty
regards,
gobinatty
19 years 4 months ago #11691
Replied by Chris on topic Re: creating Roaming Voip connectivity through VPN: Urgent Help
Gobinatty,
Using your IP Softphone over a VPN link shouldn't be much a of a problem if your able to establish a fast VPN link to your office.
So you might ask 'How will this be done?"
It's quite simple actually - you can either purchase dedicated VPN equipment which usually resides at the premises we want to access (in your case - your office) and then load a VPN client on our laptop/pc which will allow the VPN tunnel to be created between the two end points.
Once the connectivity part is complete, its a matter of configuring your softphone to enable the service over this new link.
Because you haven't mentioned anything in regards to the VPN, are you planning to create one, have one already installed or looking around for VPN solutions?
You can also setup a VPN using Windows 2000/2003 as a VPN server and terminate your XP Home laptop to it.
We'll need more information from you if you require us to be more precise with our answers.
Cheers mate,
Cheers mate,
