wireless problem
- ramachandraraju
- Junior Member
15 years 11 months ago #30249
by ramachandraraju
wireless problem was created by ramachandraraju
Hi all,
My wireless having some problem. its not connecting directly when i start the system. Every time i have to connect manually when i start the system. i am using xp sp2
Thanku
Thanku
15 years 11 months ago #30252
by Arani
Replied by Arani on topic Re: wireless problem
Check if wireless configuration zero on windows services is set to enabled and to 'automatic' startup
15 years 11 months ago #30256
by lav_plsb1
Replied by lav_plsb1 on topic Re: wireless problem
1. First, plz check whether you are using wireless card software
2. To find the wireless card software go to start/all program
3. open the software and disable it
4. later, follow the steps provided by Arani
5. under WZC (wireless zero configuation) select Recovery tab
select > First failure, second failure, subsequent failures to "Restart the service"
6. Tried connecting thru windows
7. once connected, you will be able to go online - wireless
8. Restart the computer and check are you able to go online
Note: If your w/l card software is installed, if you restart the computer, software will take a control. and you will be trying to go online with windows: then the problem starts.
I tired, its work.
I tired, its work.
