AP needs to restart every morning
16 years 2 weeks ago #29744 by Tomic
Hey alle, i have 17 ap1131ag, but one of them needs to restart every morning.
i get this log
12 Mar 1 00:00:11.862 Notification Line protocol on Interface Dot11Radio0, changed state to down
13 Mar 1 00:00:11.862 Notification Line protocol on Interface Dot11Radio1, changed state to down
14 Mar 1 00:00:11.764 Notification Line protocol on Interface BVI1, changed state to up
15 Mar 1 00:00:11.510 Notification Line protocol on Interface FastEthernet0, changed state to up
16 Mar 1 00:00:10.862 Notification Interface Dot11Radio0, changed state to reset
17 Mar 1 00:00:10.862 Notification Interface Dot11Radio1, changed state to reset
18 Mar 1 00:00:10.832 Notification SNMP agent on host ap1 is undergoing a cold start
19 Mar 1 00:00:10.832 Notification System restarted --
20 Mar 1 00:00:10.829 Notification Configured from memory by console
21 Mar 1 00:00:10.510 Error Interface FastEthernet0, changed state to up
22 Mar 1 00:00:08.345 Critical RADIO crypto FIPS self test passed on interface Dot11Radio 1
23 Mar 1 00:00:06.964 Critical RADIO crypto FIPS self test passed on interface Dot11Radio 0
24 Mar 1 00:00:05.553 Critical IOS crypto FIPS self test passed
Do someone know what my problem is, this morning i have change the switch port the AP is on, to CISCO ACCESS POINT, is at 2950 cisco switch, hope that works.
Kind Regards
16 years 2 weeks ago #29751 by S0lo
If that doesn't work, Try changing the cable reaching to the switch or at least re-crimp the RJ45 heads. If no use too, then try resetting the AP to it's factory defaults and reconfiguring. Usually there is a pin head button for resetting to factory defaults.
