Connection issues Cisco 851W and WPS54G
16 years 3 weeks ago #29638
by r0nni3
Certifications:
CCNA - Have it
CCNA Security - Have it
CCSP - Almost!!!!
Connection issues Cisco 851W and WPS54G was created by r0nni3
Recently i bought a Cisco 851W to replace a Linksys router for a customer.
The wireless connection between the router and printserver were fine before i replaced the linksys with a Cisco. But when i implemented the Cisco router things started to go wrong.
The wireless connection with the print server drops multiple times per day and requires a reboot from both the router and printserver to get it back online.
Here's the config that matters on the Cisco 851W:
dot11 ssid *
vlan 1
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid optional
wpa-psk ascii 0 *
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid *
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
bridge-group 1
interface BVI1
ip nat inside
no ip route-cache cef
no ip route-cache
Any help is greatly appreciated.
Thank you in advance!
dot11 ssid *
vlan 1
authentication open
guest-mode
wpa-psk ascii 0 *
no ip address
ssid *
station-role root
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip nat inside
no ip route-cache
Certifications:
CCNA - Have it
CCSP - Almost!!!!
16 years 3 weeks ago #29644
Replied by S0lo on topic Re: Connection issues Cisco 851W and WPS54G
I assume here that you have other clients that are connecting to the Cisco 851W wirelessly and that none of them encountered the same problem.
Here is one theory :roll:. Are you using DHCP for the internal clients? (It's not clear from the config). If you are, then I assume the print server is using a static IP. Then have you excluded the print server's IP from the 851W's DHCP config. If not, then the 851W might try to give that IP to other clients which obviously can cause conflicts.
Or, I might be totally out of the scope of the problem here. Just a try.
