detecting the IP of a wireless access point
17 years 6 months ago #29314
by sose
sose
Network Engineer
detecting the IP of a wireless access point was created by sose
I visited a production environment , so I grabbed the linksys access point and plugged it to the lan port of a my laptop.
now how do i get the IP address of this devce if my client dont know the IP. and I cant reset the access point to avoid losing its settings
sose
Network Engineer
17 years 6 months ago #29317
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic i think Sose's problem has been soughted out.....
Sose's made it tru the task... i think he's aight.
BORN TO BE GREAT
c0de - 3
17 years 6 months ago #29318
Replied by S0lo on topic Re: detecting the IP of a wireless access point
sose, if you were able to connect via DHCP. then do ipconfig /all the IP of the access point is the gateway IP shown to you.
17 years 6 months ago #29320
by KiLLaBeE
Replied by KiLLaBeE on topic Re: detecting the IP of a wireless access point
If the above fails, get either Kismet or NetStumbler. Both of these software are wireless sniffers. NetStumbler is pretty easy to install and run. I don't remember if NetStumbler will tell you the AP's IP but I know for sure that Kismet will if the security on the AP is low.
17 years 6 months ago #29333
by sose
sose
Network Engineer
Replied by sose on topic Re: detecting the IP of a wireless access point
I was mad on site because I was unabe to detect the IP but my flexibility on DOS saved me
I type arp -a and immediately got the IP and the physical address of the linksys. It was when I got home that solo's method occured to me
regarding Killabae's option
I had a sniiffer on my laptop etherdetect but did not remember to use it
thanks chaps
thanks chaps
sose
Network Engineer
16 years 2 months ago #34792
by kanna84
Replied by kanna84 on topic Re: detecting the IP of a wireless access point
Why you don't try with this site
www.ip-details.com/
for the IP address details ad searching... i too checked my IP details and internet speed test @ free of costs..
