bonded 3G mobile broadband
16 years 3 months ago #28490
by cjsmith22
bonded 3G mobile broadband was created by cjsmith22
anyone know if its possible to bond 3G mobile broadband connections?
16 years 3 months ago #28491
Replied by S0lo on topic Re: bonded 3G mobile broadband
Can you tell us what do you mean by bonding the connections ?
16 years 3 months ago #28496
by cjsmith22
Replied by cjsmith22 on topic Re: bonded 3G mobile broadband
sorry i think i've got confused between bonding and load balancing :oops:
i've got 2 3G simcards and 2 3G modems and i wanted to know if i could perform some kind of load balancing between the 2 links. ive seen adsl bonding but that has to be done by your isp doesnt it? i think i need to do a bit more research!
16 years 3 months ago #28504
by Kajitora
itgamers.blogspot.com
Replied by Kajitora on topic Re: bonded 3G mobile broadband
Well,
It is possible to do static routes in windows. Guide here:
infocenter.guardiandigital.com/manuals/SecureVPN/node65.html
So you could connect both connections then add in your bittorrent/gaming/vpn ips to one, and then use the other connection for everything else. This would be effective if you are say, connecting to VPN for work, but also surfing the internet.
So basicaly:
Connection A Gateway: 10.0.0.1
Connection B Gateway: 192.168.1.1
Say your VPN connections was going to: 68.69.69.10 you could force that to 10.0.0.1
Then set Connection b as your primary connection for internet explorer.
Hope this helps.
So basicaly:
Hope this helps.
14 years 9 months ago #34969
by rynmackz
Replied by rynmackz on topic Re: bonded 3G mobile broadband
In this kind kind of situation, maybe you are actually looking for a software to bond connection you called. Using Ubuntu could be the answer. It is positively reviewed by many consumers because of its great features.
- triplezseoservices
14 years 7 months ago #35351
by triplezseoservices
Replied by triplezseoservices on topic Re: bonded 3G mobile broadband
I think you want some kind of software which solve the or make easy your Multiple Internet Connections with Load Balancing and Failover just check this link for the further information.
www.zeroshell.net/eng/load-balancing-failover/
__________________
SEO Expert Company
__________________
SEO Expert Company
