3COM Wireless Router
16 years 10 months ago #26432 by bazhef
3COM Wireless Router was created by bazhef
I have managed to get locked out of my router.
Its a 3CRWDR101A-75
I had set it up to have a WPA password for security buy when i had to remove the usb remote, it now asks for the password which i dont have!!!
I also cannot access http://192.168.1.1 to get into the settings for the router.
Can anyone please offer me advice on how to solve this problem and get me back online? (I'm posting this at work)
16 years 10 months ago #26439 by S0lo
Replied by S0lo on topic Re: 3COM Wireless Router
As a last resort. You could manually reset the router to the factory defaults. There is usually a small button that you could reach with a matchstick or some thing. Usually you have to press it for 5 seconds or so. Check your manual, you might need to do it while powering on.
16 years 10 months ago #26480 by jaishakk
Replied by jaishakk on topic wireless
hi,
do u have any port which is to connect the rj45 ( Lan cable).
if it is so connect ur pc or laptop to that router, change the local system ip in to that router range like 192.168.1.10.
try to access the webpage.
now u will be access the routers page. from there u could change the wireless settings
