how to disable the wireless portion on Linksys routers ..
18 years 2 months ago #19855 by blesson
:?: how to disable the wireless portion on Linksys routers ..
18 years 2 months ago #19863 by DaLight
There should be an option in your router GUI under the "Wireless" tab to disable wireless. What is the model of your linksys router?
18 years 1 month ago #19955 by guru_linksys
blesson wrote: :?: how to disable the wireless portion on Linksys routers .. [/quote
could you please let me know the model no of the router.
how ever you can log on to www.linksys.com/support .
go to easy answers and in search field you can type your question.
it will give you the related topic.>>>> getting any issue further you can call on to 18003267114[/color]
