WIRELESS MONITORING....
18 years 2 months ago #19547 by talk2sp
sorry i did not knw which topic to put this.
THIS IS IT - PERMIT MY CAPS. -
I HAVE A WIRELESS ROUTER WHICH DISTRIBUTES WLAN SERVICES RIGHT. I THEN INSTALLED A SOFTWARE CALLED ANTAMEDIA (HOTSPOT SOFTWARE). ITS A KIND OF BILLING SYSTEM FOR THOSE USING D WIRELESS LAPTOP SO AS TO BE ABLE TO CONTROL USAGE RIGHT NOW WE NOT TALKING ABOUT THE WEP THATS FOR SURE BUT WHAT THE SOFTWARE DOES IS TO REGULATE THE USAGE. I GOT TIRED OF CHANGING MY WEP KEY EVERY 1.5 HOURS SO I DOWNLOADED THIS SOFTWARE AND REGISTERED IT BUT AS SOON AS I LAUNCHED IT AND ENABLED DHCP ON IT THE OTHER SYSTEMS I MEAN CONNECTED VIA LAN WILL NOT BE ABLE TO PRINT. BUT ONCE I UNCHECK IT AND EXIT THE SOFTWARE EVERYTHING BECOMES BIZ AS USUAL.
THE QUESTION IS -
1. DO U THINK THE SOFTWARE IS CLASHING WITH THE DLINK ROUTER CONFIGURATION. (MY ROUTER MODEL NUMBER IS DLINK 524, 802.11g/2.4ghz)
2. WHAT DO U THINK I SHOULD DO. BECAUSE I NEED TO LIMIT THE USAGE.
3. IS THERE ANY OTHER SOFTWARE WHICH WILL NOT GIVE SAME TROUBLE AS THIS ANTAMEDIA STUFF.
4. LAST BUT NOT THE LEAST QUESTION - PLS DONT BE ANGRY THAT I DID NOT PUT THIS IN POST I TRUSTED PARTICULAR PEOPLE WHO ARE SO INTELLIGENT TO ANSWER ME ON TIME....
CHEERS BUDDY..
TILL I HEAR FROM U...
YOURS SINCERELY,
ONIPE PETER ADEIKA
BORN TO BE GREAT
c0de - 3
18 years 2 months ago #19557 by d_jabsd
Replied by d_jabsd on topic Re: WIRELESS MONITORING....
No.
Please knock it off.
Caps = Yelling.
It also makes your post much harder to read, and makes you look bad, as a competent, respectful admin would never use all caps.
I'm tired of your all capital posts. It does not indicate emergency or importance. It indicates a lack of even the most basic knowledge and etiquette.
and its just plain annoying.
18 years 2 months ago #19559 by talk2sp
Replied by talk2sp on topic are u after.....
d_jabsd are u after helping me or my caps anyway this is my question without caps...
THE QUESTION IS -
CHEERS BUDDY..
YOURS SINCERELY,
ONIPE PETER ADEIKA
BORN TO BE GREAT
c0de - 3
18 years 2 months ago #19572 by buulam
Replied by buulam on topic Re: are u after.....
Actually, its still in caps.
THE QUESTION IS -
CHEERS BUDDY..
YOURS SINCERELY,
ONIPE PETER ADEIKA
