i need help (Belkin Wireless) !!
- mysterys1992
18 years 5 months ago #17698
by mysterys1992
i need help (Belkin Wireless) !! was created by mysterys1992
i have a belkin router and i went into settings , and basically fucked it i now carnt connect to internet on any wireless....
i did something like a home access point and i have also tryed to reset router with the pin but nothing happens if any one can help me it will be great
p.s its the router belkin are giveing away
and im 13 so i need my internet lmao
:lol:
18 years 5 months ago #17709
by Arani
Replied by Arani on topic Re: i need help (Belkin Wireless) !!
get a firmwire upgrade, it will reset the router automatically and let you configure it again
16 years 7 months ago #27339
by Lav_plsb
Replied by Lav_plsb on topic Re: i need help (Belkin Wireless) !!
First, open Internet Explorer and type in "192.168.2.1" to open router setup page.
and check the Internet status
If you are unable to open, check the ip address on your computer (Run>type in "cmd"> type in "ipconfig")
If the ip address is invalid or media disconnected or 192.168.2.254 then you need to reset the router to get the correct ip address. If you reset the router, you need to reconfigure the router.
Note: You can update the firmware through the DOS prompt or Only through Router setup page using "Firmware Update" option
