wifi card ???
- futurelogix
19 years 4 months ago #12091
by futurelogix
Take life as it comes
wifi card ??? was created by futurelogix
Hi ,
I have a laptop which doesnt have any internal wireless card ...but it is wifi compliant ...i need to buy external wifi card and i have h ave a slot for it ! But i am confused ...
whether i should buy wifi card ? or usb wireless adapter ?
pls recommend me which one should i buy ...if possible the brand too ...
thanks in advance !
I removed this thread from “Hilarious Stuff And Sites” To here were it would better fit.
Forum Moderator,
Jack Burgess
thanks in advance !
Forum Moderator,
Jack Burgess
19 years 4 months ago #12177
by ping
Replied by ping on topic Re: wifi card ???
Hi futurelogix,
Today many laptops comes wiht built in wi-fi card. So can you tell me the company and model of the laptop so that it can be decided that wether your laptop has inbuilt Wi-fi card or not? If not then i can suggest you the card.
Cheers..
~Pranav
Cheers..
~Pranav
