- Thank you received: 10
Wireless Grief
19 years 3 months ago #12240
by Arani
Replied by Arani on topic arrangements
so what i have done is, keep the adsl speedtouch router, hook up a RJ45 cable from it to the back of my desktop to utilize the lan connection, and use my laptop for the wireless option. either way my laptop always connected to the router didn't it?
so that's sorted!!!
and about why it did not see any usb dongle, i will leave it for R&D for the future
so that's sorted!!!
19 years 3 months ago #12275
by Arani
Replied by Arani on topic never say die
precisely, that is why i have left it for R&D for the future, which should technically be right after christmas. as of now, i just want to enjoy a few days free of tension regarding why something is not working inspite of my sincerest attempts of trying to rectify it.
19 years 3 months ago #12361
by Arani
Replied by Arani on topic its alive.....its allllliiiiivvveee
it works....i brought it all up, at my uncle's place, and all the netgear devices work. we are all dressed up and ready to go, and guess what...we have an entire planet to roam about!!!
19 years 3 months ago #12363
by DaLight
Replied by DaLight on topic Re: Wireless Grief
Very puzzling indeed!
- naughtypaul
- Junior Member
19 years 3 months ago #12402
by naughtypaul
NaughtyPaul
Replied by naughtypaul on topic Re: Wireless Grief
Hi Arani
Let me confirm few things again....
1. With the SpeedStream Router only the 120G and the built-in broadcom card works
2. The two 121G you have don't even connect in Ad Hoc Mode
3. With the NetGear, your 120G, 121G and the Built-in card works..
Now based on the model numbers I learnt the following from the internet
1. Your Spped Stream is a 802.11b Based Wireless router
2. Your Netgear is 802.11b and 802.11g based wireless router.
3. The 120G and 121G are 802.11g based products but are also backward compatible.
::::::::::::::::: My Doubt ::::::::::::::
I doubt that the Speed Touch 121G adapter is not negotiation properly on the Transmission speed
:::::::::::::::::Solution ::::::::::::::
1. I don't know whether you have tried all these or not... Let me sum them up and wait for your reply
>>> Please set the Transmission Rate on your SppedTouch 121g to a lower rate (Say 8 Mbps) ..
>>> Confirm that there is no MAC address blocking enabled in your Speed Stream
>>> Confirm that there is no form of encryption enabled in the Router.
2. Also looking at the router's manual I could see a setting named "Access Control" with the Ma Address of the Wireless Card set to enable or disable. Kindly look at that tooo...
well that's it for now.... Hope to get a good news soon from you.
Paul
Paul
NaughtyPaul
