Wireless hub losing connection
19 years 5 months ago #11312
by sbale
Wireless hub losing connection was created by sbale
Hi there,
My name is Herbs,
I am currently working on a small project about setting up a small wireless network to form part of a bigger existing network. I have been playing around with the wireless router for a while now but the problem is it keeps on losing the signal, which means i have to restart it every time this happens. Now you can imagine if this where to happen on a "life" network. I have tried countless things to try and correct the fault without any luck. First someone suggested that the power supply in our building might not be stable and this could be the reason why the hub just suddenly goes down. But after having done a complete rewiring of the building, the problem still persist though it was solved temporarily as the network was stable for at least a week. I have also tried to use a UPS to support the router but also this helped only for a while. Can someone please help cause i think i might be missing something.
My name is Herbs,
19 years 5 months ago #11314
Hi Herbs
Could be interference from another wireless network/transmitter on the channel you're using. Try changing channel or doing a wireless site survey. Another possibility is a client problem, for example with Netgear USB Wifi cards under XP the Netgear software can conflict with the Windows native service and cause periodic connection drops
19 years 4 months ago #11761
by sbale
Replied by sbale on topic Re: Wireless hub losing connection
Hi there,
Sorry for only responding now, have been in and out of the office this last past weeks, thanx for the response though. The problem was actually hardware related. After having consulted with the relevant vendor it was actually found that the hub was faulty. I got a new one and it works fine.
