Help required on USB Port
- smartguyz2002
20 years 1 month ago #7303
by smartguyz2002
Help required on USB Port was created by smartguyz2002
Hi friends ,
One of my USB port on the Laptop Is Not working ,
It does not read any thing that I plug into it ..
Is there a way we can fix this or Can anyone suggest me how to fix it .
Please advise
Cheerz
Please advise
Cheerz
20 years 1 month ago #7304
by KiLLaBeE
Replied by KiLLaBeE on topic Re: Help required on USB Port
Assuming that you have windows, only thing I can suggest is to:
Make sure you have the latest updates and service packs, the latest hardware drivers, make sure that usb port is enabled in the bios or device drivers.
20 years 1 month ago #7306
by MezzUp
Replied by MezzUp on topic Re: Help required on USB Port
Make sure USB is enabled in the BIOS
20 years 1 month ago #7307
by cyberoidx
Surya Sharma
www.Technodrome.info
AR3 Y0U T3CH ENOUGH FOR IT?
Replied by cyberoidx on topic Re: Help required on USB Port
If software changes dont help you, try getting it repaired.......or get those USB extenders, that convert 1 uSB port into 4.......
Surya Sharma
20 years 1 month ago #7334
by ping
Replied by ping on topic Re: Help required on USB Port
Some times pins that are there in USB ports may be torn a side due to some reason or due to inserting or removing USB device improperly try to check it out and if this is probleme you better go and change it.
