after re-installing O/S the system hang b4 desktop environme
15 years 4 months ago #31759 by lmcares4u2003
have try 2 press Ctrl + Alt+ Del but there is no reply....its yield no result. i can see that the processor doesnt have enough capacity 2 run d program becos everytin is onboad...
15 years 21 hours ago #33234 by lmcares4u2003
14 years 11 months ago #33246 by S0lo
then i now remove the hard disk and use another board to load the hard disk then the hard disk work perfectly with the system..PLEASE REPLYYYYYYY...
Since it worked with another mother board this can indicate a hardware problem with the other mother board. If those boards are identical clones, then it's a bit strange, because a faulty mother wouldn't normally even boot!! Unless I'm missing some thing here.
I'd try to first blow the mother board with a blower to get rid of any dust.
Another thing, did you surface scan the hard drive, It could be a bad cluster. To scan it, boot from the Windows CD, when the options come, press "C" to go to the Recovery Console. When you get the command prompt, type:
chkdsk c: /R
The process will take some time to complete.
14 years 11 months ago #33396 by lmcares4u2003
thanks, have done somethin similar 2 dat....but i wil stil do it again
Time to create page: 0.126 seconds
