USB drive slow
- psiclonius
- Junior Member
17 years 10 months ago #22149
by psiclonius
USB drive slow was created by psiclonius
Hey everyone,
Are USB 2.0 and USB-High speed the same? I have a 200GB file I need to transfer to another system. It crawls over the network so I got a USB portable HD hoping it would be faster. I have it connected to a HP proliant DL380 G4 and was curiour to know if I need to get a PCI USB interface card to get a faster transfer rate. Right now it take about 20 hr to copy the file.
17 years 10 months ago #22158
Replied by TheBishop on topic Re: USB drive slow
Not sure about USB Hi speed. However if your disk is USB2.0 then you need a USB2.0 port on your server to get the benefit. A USB2.0 device pluged into a USB1 port will crawl
17 years 10 months ago #22166
by DaLight
Replied by DaLight on topic Re: USB drive slow
Yes, USB 2.0 and Hi-speed USB are the same thing. The comparison obviously being made with USB 1.1 which has a theoretical maximum of 12Mbps as compared with USB 2.0's 480 Mbps.Are USB 2.0 and USB-High speed the same?
