kvm switch for 2 monitors
17 years 10 months ago #22052 by skylimit
Hi, I've got two monitors (one for windows and the other for linux box). I was wondering if its possible to use a kvm switch to control both systems so i can easily switch b/w the 2 display, rather than have one display for the two systems... so far i have seen kvms with a single port for just one monitor. can this do the job or is there a diff one for my need? any posts and link(s) appreciated. many thanks
17 years 10 months ago #22056 by KiLLaBeE
You can use a regular 2-port KVM to accomplish your needs. It would be setup in the following way:
monitor 1 would be directly connected to computer 1. monitor 2 would be directly connected to computer 2. The two ports on the KVM used for the keyboard and mouse would be connected to the two computers. One keyboard and mouse (the ones you will use) will connect to the KVM. So basically, the monitor port on the KVM will not have anything connected to it.
That shouldn't affect the KVM's functionality, unless the KVM you are using is weird and requires the monitor for signal detection and whatnot, but most KVMs use the keyboard and/or mouse for that instead.
K
17 years 10 months ago #22060 by skylimit
thanks mate....so from what u've described i can easily switch between the two displays from the keyboard say using scroll lock key.
...I'll try it out and return here if it dont work...sounds logical so i gues it wuld. many thanks
17 years 9 months ago #22245 by Lindows
Replied by Lindows on topic A second Chance
Hey Guys
My KVM died on me a couple of days ago. Little did i know after throwing it away, and finally reading the manual. It wasn't dead, but i didn't know how to switch between monitors display by pressing "Scroll lock" Well that my heart ache revealed .
lindows
