My Monitor shocks like a 220v live wire
18 years 2 months ago #19534
by oshabby
Ayokunle Saba (oshabby)
Wizards Solutions Ltd
Akure, Ondo State
Nigeria
My Monitor shocks like a 220v live wire was created by oshabby
Pls I need help for my monitor.whenever I power it and switch it on, the screen and the front chassis shocks badly. It is a Mercury CRT(Cathode Ray Tube) Monitor - 17"(17 inches) :!:
pls help!!!!!!!!!!!!!!!
Akure, Ondo State
Nigeria
18 years 2 months ago #19561
Replied by TheBishop on topic Re: My Monitor shocks like a 220v live wire
Extreme danger!
Stop using it at once and get it checked out. Also check the wiring of your mains lead on the monitor and the socket from which it is powered. You might have the live and earth reversed or perhaps the earth missing or disconnected.
Either way it needs looking at
18 years 2 months ago #19586
by Starfire
Replied by Starfire on topic Re: My Monitor shocks like a 220v live wire
Monitors start going bad best to get rid of them. Cut the cable so nobody else will try to use it and take it to the local dump.
I've seen one of those things catch fire (luckily I was around at the time) and they can really go. Plus if the screen goes bang you really don't want to be within 10 feet of it.
Really not worth the risk.
