CRC-8 - How to obtain the best generator polynomial?
19 years 4 weeks ago #9786
by dodo
CRC-8 - How to obtain the best generator polynomial? was created by dodo
As I know the standard CRC-8 value is x8 + x2 + x + 1
But I wonder how they obtain that value for CRC-8?
For example, to generate the FCS for a message N bits long, how can I define my best generator polynomial CRC-M (M is the suitable bits length) and its own value.
Thank you very much.
Time to create page: 0.111 seconds
