ccna questions (FinaL)
19 years 10 months ago #8629
Interesting stuff. To clarify this then:
1) An "active hub" is what we all call a hub, i.e. a multi-port repeater
2) An "intelligent hub" is a managable hub (for definition of hub see above)
3) A passive hub is - what? The only thing I know that can connect devices or segments without including any signal regeneration is a piece of cable..
So what IS a passive hub????
19 years 10 months ago #8642
by ping
Replied by ping on topic Re: ccna questions (FinaL)
Correct me if i m mistakeing but as far as i know passive hub is a just a simple connector that just receives data from one of it's ports and repeats it to all other ports where as active hub does that and also it does signal regeneration.
19 years 10 months ago #8647
by MezzUp
Replied by MezzUp on topic Re: ccna questions (FinaL)
yebb, I think that's about itCorrect me if i m mistakeing but as far as i know passive hub is a just a simple connector that just receives data from one of it's ports and repeats it to all other ports where as active hub does that and also it does signal regeneration.
