differentiate cat5 cat3 cable
20 years 4 days ago #8111 by trmmjpz
By looking at the cable can you tell if it is a cat3 or a cat5/5e cable?
- K
20 years 4 days ago #8112 by The_Berzerker
Usually cables have some printed information on them, one of them is the category of the cable :wink:
Take a look at any cable and you will see for yourself
20 years 12 hours ago #8157 by TheBishop
Replied by TheBishop on topic Cat5
The more recent cables such as Cat5 and Cat5E are certainly marked. If the cable is older and doesn't say that it is Cat5 then be suspicious because it might not be. Ultimately though, the only way to tell the type of an unmarked cable is to test it
