Connection Problem!
20 years 3 months ago #6437 by eli2983
Connection Problem! was created by eli2983
hi, I have 2 computers connected by RJ-45 cabble.Win xp is the OS that runs on the computers.
The problem:
I have a reply for a ping from one computer(x) to the other computer (y) but dont have a reply from the other computer(y) to the first one(x).
I have to mention that no firewalls or other devices that can block ports or connections is involved here!
thank you for helping me :)
20 years 3 months ago #6438 by collin
Replied by collin on topic Re: Connection Problem!
:roll:
Hi Eli First check the class of Ip's you have posted on. USe class A ip series that 10.0.0.1 series . Have one machine as 10.0.0.1 & the other 10.0.0.2. Have their Subnet masks configured to 255.0.0.0 for both the machines and then try to ping from one machine to the other and vice versa
That should solev your problem..
:roll:
20 years 3 months ago #6439 by jhun
Replied by jhun on topic Re: Connection Problem!
hi,
you could also try and check your cable. see to it that it was crimped properly and that color codes were followed. since you are using a UTP cable it should be in the crossover format standard.
