IP addresses subnet question
20 years 7 months ago #6085
by kesmond
IP addresses subnet question was created by kesmond
Hi all, read the articles that Chris had published on this website about subnetting.
Had some questions and need you guys to help me with it.
I know that we subnet becos we need to break down into smaller networks, how come we cannot use devices like switches or routers to do so?
20 years 7 months ago #6087
by sLz
Replied by sLz on topic Re: IP addresses subnet question
Well, we do use Routers to seperate the Subnets once we've split them. All the Subnet is, for example:
Network IP: 10.23.4.5
Subnet Mask: 255.240.0.0 (Class A)
So now when you convert all the decimals to binary, the Router for example, will perform a boolean logic AND on the Binary values which will give out the Network address of that particular subnet. When routing across the net, Routers know it's a class A IP and therefore don't care about the other 3 octets.
As soon as you Subnet you split the network - you understand that, Switches and Routers now know on which port the particular Network is, for example it knows 10.0.0.0 is on Interface 0. As Chris pointed out in his guide that you cannot speak to one another, once subnetted, without a Router to route the packet to its correct destination.
If you weren't to Subnet then you will have 16 or so million hosts in a class A IP scenario. All on the same broadcast domain and causing alot of unneeded traffic through these broadcasts, which may be generated by many things such as collisions.
Subnetting makes the whole network infrastructure alot easier.
*Rubs eyes* My apologies if this is not specific enough. I blame it on the early morning
- who wouldn't?
Time to create page: 0.079 seconds
