Slowing Down LAN Speed
20 years 10 months ago #3953
by ddimitrov
Slowing Down LAN Speed was created by ddimitrov
Is there any way to emulate a slower LAN connection than you currently have?
For example, if you are on an 100Mbps LAN, but want to see how an win32 application (not Internet tool) looks at 128 or 64 Kbps?
20 years 10 months ago #3968
by sahirh
Replied by sahirh on topic Re: Slowing Down LAN Speed
If you look in the cool software forum you'll find someone (I think Neon) had posted something about some software that lets you decide the bandwidth available to any application that you run.
Sounds like what you're looking for
