Conversion of Decimal to Hexa and Hexa to Decimal
20 years 10 months ago #3894 by ajnabi
Hi every body.
I have the problem of Conversion from Decimal to Hexa
and Hexa to Decimal can u plz tell me?
20 years 10 months ago #3895 by dreamer
Well if you have windows you can use your calculator under the bureau accessories. It has the possibilty to switch between binary, decimal and hexadecimal. So you can easily convert using that.
You can also try looking for tools on the net but since the calculator can do it there is no need to look for it I believe.
The theory behind the conversion is rather simple. For instance
0 (hex) = 0000 (bin) = 0 (dec)
1 (hex) = 0001 (bin) = 2^0 = 1(dec)
2 (hex) = 0010 (bin) = 2^1 = 2(dec)
3 (hex) = 0011 (bin) = 2^0+2^1 = 1+2 = 3 (dec)
F (hex) = 1111 (bin) = 2^3+2^2+2^1+2^0= 8+4+2+1 =15(dec)
You can also translate directly for instance: 28 HEXADECIMAL to DECIMAL
= 2* 16^1 + 8* 16^0 = 32 + 8 =40
I hope this solves your problem.
Greets
Dreamer
