simplest way to use an ethernet cable
13 years 7 months ago #37313
by parveny
simplest way to use an ethernet cable was created by parveny
What is the simplest way to use an ethernet cable? I saw a video where a guy opened his brand new 360 elite. And one thing was an Ethernet cable. I searched how to use an ethernet cable on google and i was getting sites with either too much detail or too little. I need the simplest way to describe how to use an ethernet cable.
___________________________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
13 years 7 months ago #37315
by Nevins
Useful Threads
Replied by Nevins on topic Re: simplest way to use an ethernet cable
You use it the same way you use a power cable. You plug it in.
One end plugs into your xbox 360.
The other end plugs into the device given to you by the company that sells you internet.
You really shouldn't be able to mess it up, your basically plugging in a cable into the only hole that looks like it will fit the cable.
Useful Threads
