Will an Ethernet Splitter work
13 years 8 months ago #37276
by parkery
Will an Ethernet Splitter work was created by parkery
How do I use the internet with the ethernet cable plugged in? My ethernet cable is plugged in from the router, my internet works fine, but it still keeps connecting to the weak wireless connection instead. How do I switch over to the ethernet cable internet connection?
________________________
market samurai ~ marketsamurai ~ marketsamurai.com
13 years 8 months ago #37277
by rizin
Replied by rizin on topic Re: Will an Ethernet Splitter work
Which router model do you use ?
13 years 8 months ago #37278
by Arani
Replied by Arani on topic Wireless NIC
Hi
Have you tried disabling your wireless NIC on your computer/desktop/laptop. That way the only available and enabled networking interface would be your ethernet card.
13 years 8 months ago #37279
Replied by TheBishop on topic Re: Will an Ethernet Splitter work
Check if you have a wireless switch/button on your laptop for that purpose. That's much easier than doing it within windows
