RIP Not showing in Show ip route
13 years 8 months ago #37239
by rizin
RIP Not showing in Show ip route was created by rizin
Hi All,
Please look at this table, my problem is i cannot able to find any RIP Routes in show ip route table
Where i'm going wrong ?
Thanks in advance,
Rizin
Thanks in advance,
Rizin
13 years 8 months ago #37240
by Nevins
Useful Threads
Replied by Nevins on topic Re: RIP Not showing in Show ip route
Your link is broken.
Configuring and troubleshooting rip is VERY easy here are the requirements of rip:
Interfaces in the UP/UP state (check with show ip interface brief)
(note: to be in an UP/UP state ip addresses have to be given out, the cable has to be connected and both ends must be using the proper encapsulation and authentication)
Router RIP command enabled (check with show run)
Version (check with show run)
Networks properly advertized (check with show run)
Useful Threads
13 years 8 months ago #37242
by rizin
Replied by rizin on topic Re: RIP Not showing in Show ip route
Hi nevins,
Link is opening for me, can you try this.
[img=http://img156.imagevenue.com/loc177/th_281409236_ripconfig_122_177lo.PNG]
13 years 8 months ago #37243
by Nevins
Useful Threads
The link appears to work now. In any case you are going to need to do more show commands to pinpoint the issue.
Check the output for
Show ip interface brief (check link status)
Show run (check overall config for issues)
In the future just paste the text, it's so much easier then hosting.
Useful Threads
13 years 8 months ago #37247
by rizin
I'm afraid it is very long text, please bear with me
R1#show run
Building configuration...
Current configuration : 1017 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 192.168.27.2 255.255.255.0
interface FastEthernet0/0
ip address 192.168.26.2 255.255.255.0
duplex auto
speed auto
interface Serial1/0
ip address 192.168.25.1 255.255.255.0
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router rip
network 192.168.25.0
network 192.168.26.0
network 192.168.27.0
no auto-summary
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R1#
R1#
R1#show ip interfa
R1#show ip interface brie
Interface IP-Address OK? Method Status Protocol
FastEthernet0/0 192.168.26.2 YES NVRAM up up
Serial1/0 192.168.25.1 YES NVRAM up up
Serial1/1 unassigned YES NVRAM administratively down down
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Loopback1 192.168.27.2 YES NVRAM up up
R1#show ip protocols
Routing Protocol is "rip"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Sending updates every 30 seconds, next due in 14 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: rip
Default version control: send version 1, receive any version
Interface Send Recv Triggered RIP Key-chain
FastEthernet0/0 1 1 2
Serial1/0 1 1 2
Loopback1 1 1 2
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
192.168.25.0
192.168.26.0
192.168.27.0
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 120)
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.25.0/24 is directly connected, Serial1/0
C 192.168.27.0/24 is directly connected, Loopback1
C 192.168.26.0/24 is directly connected, FastEthernet0/0
R1#
Thanks in advance,
Rizin
R1#show run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
duplex auto
speed auto
interface Serial1/0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router rip
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R1#
R1#
R1#show ip interfa
Redistributing: rip
Serial1/0 1 1 2
Loopback1 1 1 2
Maximum path: 4
192.168.25.0
192.168.26.0
192.168.27.0
R1#show ip route
R1#
Thanks in advance,
Rizin
13 years 8 months ago #37248
by Nevins
Useful Threads
Lets go over our checklist:
Networks properly advertised
[code:1]!
interface Loopback1
duplex auto
speed auto
interface Serial1/0
Networks and interfaces defined:
network 192.168.25.0 = Serial1/0
network 192.168.26.0 = FastEthernet0/0
network 192.168.27.0 = Loopback1
[code:1]R1#show ip interface brie
Loopback1 192.168.27.2 YES NVRAM up up [/code:1]
network 192.168.25.0 = S1/0 = UP/UP
network 192.168.26.0 = Fa0/0 = UP/UP
network 192.168.27.0 = L1 = UP/UP
[code:1]!
router rip
no auto-summary
! [/code:1]
Version (default is version1)
network 192.168.25.0 = S1/0 = UP/UP = Rip version 1 advertisements
network 192.168.26.0 = Fa0/0 = UP/UP = Rip version 1 advertisements
network 192.168.27.0 = L1 = UP/UP = Rip version 1 advertisements
You'll notice that I didn't check off Networks properly advertised and there is a reason for that. Namely the networks are not being properly advertized.
Here is you need to look:
How does RIP version 1 differ from RIP version 2 specifically for advertizing networks.
Are all devices properly configured (advertizements work more then one direction)
Here are some tools for you:
#Debug IP RIP (will show you what advertizements are being sent from where)
(think classless vs classful)
At this point I can pretty much tell you the problem but given that we are dealing with RIPv1 I'm guessing that this is a lab so I'll let you dwell on it. But in the mean time keep in mind that there are only a few parts to rip:
Is rip enabled
Is rip the same version (only sort of matters)
Are the links up/up
Are you properly advertising your networks. (most problems generally found here)
[code:1]!
interface Loopback1
duplex auto
speed auto
interface Serial1/0
[code:1]!
router rip
no auto-summary
! [/code:1]
Is rip enabled
Are the links up/up
Useful Threads
