Variable-Length Subnet Masks
14 years 4 months ago #36084
by ping
Variable-Length Subnet Masks was created by ping
I was reading about variable length subnet masks on one of the presentations from one site and I came across this particular site which contained some statements I was unable to understand.
The site was explaining about various possible VLSM assignments.
The slide had following content.
I would be very thankful if someone could explain how these assignments are carried out.
Title: Use Of Address Space (Start With 16 Bits Of Host Suffix)
Thanks...
Ping
One possible VLSM assignment (92.9% of addresses used)
11 networks of 2046 hosts each
24 networks of 254 hosts each
256 networks of 126 hosts each
Another possible VLSM assignment (93.1% of addresses
used)
9 networks of 2046 hosts each
2 networks of 1022 hosts each
40 networks of 510 hosts each
160 networks of 126 hosts each
Thanks...
Ping
14 years 4 months ago #36086
by Chojin
Replied by Chojin on topic Re: Variable-Length Subnet Masks
VLSM is a word for not using classfull subnets.
the 10.0.0.0/8 is a classful subnet, when using VLSM (that is variable length subnet masks) you can for example split the 10.0.0.0/8 up in multiple networks.
10.1.0.0/16
10.2.0.0/16
10.3.0.0/24
10.3.1.0/24
etc. This way you can make your networks smaller (or larger when supernetting) and adjust it to your needs.
Hope this sheds a bit of light
10.1.0.0/16
10.2.0.0/16
10.3.0.0/24
10.3.1.0/24
14 years 4 months ago #36088
by rizin
Replied by rizin on topic Re: Variable-Length Subnet Masks
Hi Ping,
On Which Class Address they want to apply those VLSM e.g A, B, or C, so that you will able to know the answer precisely.
Rizin
Rizin
14 years 4 months ago #36089
by ping
Replied by ping on topic Re: Variable-Length Subnet Masks
Thank You Chojin, the issues is clear now..
14 years 4 months ago #36090
by ping
rizin, in the example I was reading it was referring to class B addresses..
Time to create page: 0.087 seconds
