ethernet connection
14 years 3 months ago #36056 by parkery
ethernet connection was created by parkery
How do connect my broadband when my computer does not have an ethernet connection? I have just had broadband installed and the modem needs to connect to my computer via an ethernet lead. The trouble is I do not have an ethernet connection on my computer. Is there a way I can connect in other ways?
__________________________
external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com
14 years 3 months ago #36060 by Arani
Replied by Arani on topic ...
Hi there
Is there an option to use an USB cable with your broadband modem?
Or else why don't you get an Ethernet card for your PC. They are dirt cheap!!!
14 years 3 months ago #36066 by rizin
Replied by rizin on topic Re: ethernet connection
Hi Parkery,
There are ways to connect however still you have to buy some.
1) USB Wireless Adapter if your Broadband Modem supports Wireless Connection. (Connect with PC)
2) USB Lan Adapter also available in the Market. (Connect with PC)
Good Luck !
Rizin
14 years 3 months ago #36072 by S0lo
Replied by S0lo on topic Re: ethernet connection
You have good suggestion above. May I add that the cheapest, most reliable and fastest would probably be getting an Ethernet card. Sure you need a UTP cable with that too.
