Questions before taking CCNA
14 years 8 months ago #35157
by Aizzaac
Questions before taking CCNA was created by Aizzaac
Hello
I am studying for a CCNA certification. I have some questions.
1. Does a DHCP server use gratuitous ARP before leasing IP addresses?
2. Differences between CIDR, VLSM and route summarization?
3. Can a host belong to many different VLANs at the same time? What would be its porpose?
4. Examples of networks Multi access broadcast, and no multi access broadcast.
Thank you
[/list]
Thank you
14 years 8 months ago #35163
by SujitNair
Replied by SujitNair on topic Re: Questions before taking CCNA
Hi Aizzaac,
Please find the answers inline:
Ans: Yes Gratuitous ARP and ping are used by the DHCP to detect conflicts. Usually DHCP clients use Gratuitous ARP for checking conflicts and ping is used by the server.
Ans: Guess this will help:
www.xs4all.nl/~itbg077/studieavond/IP/IP-Summary.pdf
Ans: A host can belong to only one Vlan at a particular time, usually we have servers with multiple NICs which are in different VLANS, basically used for load balancing and stuff!
ANS: Multi access broadcast : Ethernet
NBMA: frame-relay
Hope it helps
Regards,
Sujit
NBMA: frame-relay
Hope it helps
Regards,
Sujit
14 years 8 months ago #35170
by Aizzaac
Replied by Aizzaac on topic Re: Questions before taking CCNA
Thank you Sujit.
I have some other questions..... :roll:
I. What do these mean:
1. access-list 115 permit ip 0.0.0.0 255.255.255.0 any
2. ip nat pool test 172.16.11.70 172.16.11.71 prefix-lenght 24
ip nat inside source static 10.10.10.4 172.16.6.14
ip nat inside source pool test
II. Besides Non-broadcast and broadcast multiaccess, there are
also the non-broadcast and broadcast multipoint. What is the
difference? are there any drawings?
III. Scenario: I have 2 routers kinked by a serial interface (every
router has its own lan networks too). When a packet sent from
one of these LAN networks is traversing the serial link; What
would be the source and destiny MAC address?
Regards
Regards
14 years 8 months ago #35177
by SteveP
Replied by SteveP on topic Re: Questions before taking CCNA
How close are you to taking the exam?
- broadcaststorm
- Junior Member
14 years 8 months ago #35197
by broadcaststorm
Replied by broadcaststorm on topic Re: Questions before taking CCNA
I'm guessing there is a degree of brain dumping going on here!
